10" JL W3 6ohm with Amp????
I have two 10" JL W3 6 ohm subs. I also have a 500watt 2 channel amp i would like to power the subs with.
Amp specs are:
2 x 125 Watts @ 4 Ohms
2 x 250W @ 2 Ohms
1 x 500W @ 4 Ohms
will this work to power my two JL subs??? sorry if it a *** sub woofer question.
Just wire each one up to each channel and call it a day. It won't be putting out a lot of juice the those W6's though.
Or you could try and parallel the 2 subs and then bridge the amp to get a little more power. Some 2 channel amps will tolerate a 3 ohm load bridged, some will not.
