need help with shock sensor for alarm in trans am
Others with moisture problems experience false alarms mostly at random. You have alarms because of external factors such as vibration from another car. That indicates that the sensor is too sensitive but not necessarily the common moisture problem. The difference is that drying yours probably won't help... you'll likely have to replace it.
