ASR light (in switch) not lighting
I recently replaced my radio head unit, so I had those switches removed -- but I honestly don't know if it worked before that or not. I did that the first weak I had the car (i've had it for almost a month now).
Anyway, the switch works fine, the dash light for "ASR OFF" works fine, its just the light inside the switch it self is never on.... thoughts?
Before you do that, you may want to test that it is getting power and ground. The indicator LED gets 12V power through the pink wire on the back of the switch. That wire should have power whenever the ignition is ion the RUN position. The indicator is toggled on and off through the ground side controlled by the Electronic Brake Control Module. This is through the purple/white wire at the switch.
So, if ASR is ON (default), i should have 12V+ on Pink wire, and ground on purple/white. if ASR if OFF, i should have 12v+ on pink, but no ground on purple/white. sound right?
So if you are getting power to it the LED is dead right?
What if there isn't any power going to it? How would you troubleshoot that?
Thanks
I wanted to change the color of the LED at some point too but sounds like it's a PITA kinda.
