Electrical Gurus Needed?
Old Jul 27, 2014 | 08:21 PM
RI96Z28M6's Avatar
Default Electrical Gurus Needed?
So I have a 98 Formula. When I turn my headlights on, the Drivers side is fine. The Passenger side is dim. When I turn the High beams on, the drivers side works fine. THh Passenger side doesn't work at all. Both Bulbs are off. Replaced bulb, still stays dim when on.
So Im thinking its a grounding issue. Where is the ground that works that side? Any help would be grateful.
Old Jul 28, 2014 | 07:38 AM
WhiteBird00's Avatar
Ungrounded Moderator
You are probably correct. A bad ground in a lighting circuit will often cause the current to seek ground through the other bulb filament causing both to light dimly. It also causes the symptom of the high beam causing both lights to turn off because power is being applied to both sides of the circuit and there is no ground.
The headlight grounds are on the top of the radiator housing on each side. It wouldn't hurt to check there but it is far more common for the problem to be in the lamp socket (corrosion) or the wiring close to the socket (broken connection due to flexing of the wires with the movement of the headlight motors). If the ground point on the radiator looks clean and secure, clean out any corrosion in the lamp socket and check it with a test light or multimeter. Black is ground, yellow is low beam power and light green is high beam power.
Old Jul 28, 2014 | 10:46 AM
vikingramair's Avatar
Check this connector located under the headlight unit. This connector is known to "corrode" a lot= poor conductivity.
Old Jul 29, 2014 | 12:42 AM
RI96Z28M6's Avatar
You guys were right. The connector had corrosion in it. Cleaned it all up. Works great. Thanks guys.
