2002 TA oil gauge problem
Old Aug 11, 2014 | 04:03 PM
steve-d's Avatar
Default 2002 TA oil gauge problem
Just received my car from a shop doing work on engine. The oil gauge is pegged to the max. An auxiliary gauge reads normal, so I'm not worried as to the true nature of the pressure.
The engine was removed and replaced for motor work. Nothing done to the interior or instrument panel. The ECU was removed so it could be flashed with a starting tune for the motor work.
The mechanic said he saw the oil gauge reading and tested the sender. He said it was normal. He said he thought the gauge was broken to begin with and that was the reason for the auxiliary gauge.
Where does the wiring go from the sender as I'd like to look for the short if it can be readily fixed. Does it go to the ECU or the instrument panel or .......? Any info would be greatly appreciated.
Steve
Old Aug 12, 2014 | 07:14 AM
mab6680's Avatar
the oil pressure switch is behind the intake and it should go right to the gauge if it worked before then its should be a short
Old Aug 12, 2014 | 08:32 AM
steve-d's Avatar
Thanks very much! Appreciate it. I'll advise if the short is found.
Old Aug 12, 2014 | 09:19 AM
WhiteBird00's Avatar
Ungrounded Moderator
You will not find a short. The oil pressure gauge is grounded through the oil pressure sensor in the engine which is a variable resistor. The lower the resistance, the lower the reading on the gauge. So a short to ground would cause the gauge to read low (or zero) all the time... not high as you describe.
Here is your diagnostic procedure:
- Unplug the oil pressure sensor and connect a jumper wire between the connector and a good ground. Turn on the ignition. If the gauge now reads low pressure, check that the connector is making good contact with the sending unit (if not, fix it and test again). If the connector is making good contact then the sender is faulty and must be replaced.
- If the gauge does not read low when the wire is grounded, look for a broken wire or bad connection between the sensor and the instrument cluster (tan wire in position B14 of the IP connector) by doing a continuity test with a multimeter. Repair any problem found with the wire and retest.
- If the connector, the sending unit, and the wire all check out then the gauge itself is defective.
Old Aug 12, 2014 | 05:45 PM
steve-d's Avatar
Thanks so much for the time to give your reply. Here's what I've done to date. I was under the impression the electricity of the car was causing the gauge to go to the max. I disconnected the battery and the gauge remains to the right. Sooo, I suppose the gauge isn't being shorted by an improper connection to the battery. Keep in mind the gauge remains in this position when the key is off. I thought if I removed the battery supply cable it'd drop. But nothing.
I suppose I can go through your test procedure this coming w'end.
Thanks again. Very informative.
Steve
Old Jul 10, 2015 | 01:37 PM
pitchblackZ's Avatar
Steve-d did you figure out your issue? I have the same problem. Replaced the sensor twice, replaced the plug and traced the wires. Problem seems to be the gauge itself. Any idea how or where to get it fixed?
Old Jul 10, 2015 | 01:56 PM
steve-d's Avatar
it turned out to be a broken gauge. I had to replace the entire instrument cluster. Obtained a new one on gmpartsdirect.com.
Old Jul 10, 2015 | 03:30 PM
Thank you for the quick response. Looks like I will have to do the same.
