Aeroforce analog port config help needed
Tech support determined that my gauge had outdated firmware and could not be updated. Fast forward to last night, new cn401 arrived. Wired it up and I can not get the gauge to display accurate temperatures.
I have selected to display: analog 1 and analog 2
I have set them both to fluid temp and also tried air temp.
Would prefer to be able to label them as something more appropriate.
I have also tried selecting analog configuration and played with the slope and intercept, but according to the paperwork if you use their temp sensor and choose air or fluid temp it will auto calculate.
I am confident they are not accurate because I am sure my tranny temps are not nearing 300 after only a couple minutes of idling from a cold start, and I have shot the sensor area with a infrared temp gun.
Can someone walk me thru how I should set the gauge up? It shouldn't be this complicated. Maybe one or both sensors are bad?
