5 volts to brakes constantly???
Tested the brake wire and it's getting 5 volts at all times, is it supposed to? Gets 12 volts when brake is pressed.
We're thinking that 5 volts is making the converter act up lighting both filaments in the bulb and causing havoc. Anyone? Thanks
Test at the brake switch that you have full battery voltage on the orange wire and either battery voltage (pedal depressed) or 0 volts (pedal released) on the light blue wire.
For some reason we thought it was reading right then at the pedal and at the tail light harness we are getting 5 volts and couldnt figure out why. Only thing we thought of was back feed or whatnot from the led 3rd brake light. Not the case unplugged the led spoiler light, it read 5 volts still and at the spoilers harness too.
So we are stumped.
The 5 volts is screwing me hard as the converter just doesn't like that extra voltage mixed with the turn signals.
Thanks for the help I suck with electrical but figured this wouldn't be that hard but it is
It would have been much easier to simply connect a wire from the light blue wire at the brake switch to the unused terminal P on the turn signal switch. That would make the Camaro wiring work much like Firebirds where the brakes and turn signals share the same bulbs. You could completely eliminate the trailer adapter.
Funny thing is we disconnected the the socket with the orange and light blue wire and it was still reading 4.5 volts from the rear harness connection. So something's fishy!
I doubt anything has been modded the car was stock except for a few things. Idk
