Monsoon High Pitched Tone
Old Oct 8, 2014 | 02:39 AM
02FirebirdTA's Avatar
Default Monsoon High Pitched Tone
Hello all,
As of yesterday I am back into 4th gen ownership 8 years after I sold my '02 WS6.
I finally disabled the TheftLock on my HU today and was happy to have the stereo functioning.
Unfortunately a few seconds later the speakers started emitting a very high pitched tone. It's louder if the radio is on, and does not go away when I turn the radio off or the ignition off. I have to pull the radio acc fuse to extinguish the tone. If I replace the fuse the stereo functions normally for a few seconds and then the high pitch screech returns.
Has anyone come across this problem before? Any help would be appreciated.
Old Oct 9, 2014 | 07:06 AM
wssix99's Avatar
Save the manuals!
No, but it sounds like a bad capacitor somewhere in the radio.
Old Oct 11, 2014 | 03:06 PM
zfastss's Avatar
Could be internal like wssix99 suggested. Does the pitch vary with RPM? I had a similar whine that was typical with what you might hear from a bad ground. I swapped the stock HU, the stock amp, fuses, unplugged and moved wire harnesses around and couldn't get it to go away. Finally I found my negative cable on the battery to be slightly loose, so I cleaned off the terminals and cranked it back down and the sound went away...worth a shot to see if it's as simple as that.
Old Oct 20, 2014 | 07:48 PM
01WS6/tamu's Avatar
Pull the radio out jump orange to pink with the engine running. If noise is their still the amp died. If noise goes away radio died.
