Autometer tach fix
Old Dec 1, 2014 | 06:34 PM
Huggybear19K's Avatar
So I hooked up my autometer tach.. I cut the white number 10 wire to the red connector.. Rpm signal.. I spliced my green tach wire into the white wire coming from the harness not the pcm.. I got it grounded and 12v ignition going to the tach.. When I cut the key on the tach needle goes to 0 then bounces up to the shift light limit.. Depending on what I move the shift light **** to depends were it goes.. I cut the brown and orange wire on the back of the tach to put it in 4cyl mode.. What yall think? Not a strong enough signal from the rpm?
Also since I cut the wire going to the pcm for the rpm signal.. Should my factory tach stop working?
Last edited by WhiteBird00; Dec 1, 2014 at 07:43 PM. Reason: Merge consecutive posts
Old Dec 1, 2014 | 07:40 PM
Nevermind I'm a idiot.. I hooked the the tach wire up to the wrong side of the a10 white wire
