TBSS 535t window module help
Old Jan 6, 2015 | 03:11 PM
Striker289's Avatar
Default TBSS 535t window module help
2008 Traiblazer SS
After getting my Viper Alarm install sorted out and working great I decided to Tackle A 535T Install. I currently Have the Drivers Side hooked up. Went to Test it, The window rolled down on its own now the window does not operate. Both Wires Rest at ground, when I attempt to roll up the window it sends a quick pulse of voltage to the brown wire then the switch clicks off.
The wires are ran between the switch and Motor, I've tried dipswitch 3 in both positions because the description is vague and confusing. Is this install even possible or am i wasting my time.
Old Jan 9, 2015 | 02:17 AM
Clearalbino's Avatar
On the drivers side window you will have wires that control up and down.
Brown is Down
Dark Blue is UP
Cut the brown wire and connect Green H1/2 to motor side and White H2/2 to switch side
Cut Dark Blue wire and connect Blue H1/3 to motor side and Brown H2/1 to switch side.
On this vehicle, you will have to run wires through the door boot and to the window switches for the ones you want to control. If you want up and down for all windows, then you will need to purchase another module to control the rear two windows.
