Alternator Wiring HELP
Old May 30, 2015 | 02:47 PM
Camaro9781's Avatar
Default Alternator Wiring HELP
So I'm disassembling a lot of things to pull the engine out of my car and as I take the alternator off I notice 3 out of the 4 yellow wires going into the pigtail connector are cut right off. Now before I did this the car had great battery voltage all the time and I never had a problem. The Volts gauge would read well over 13 while driving so it wasn't having any charging issues at all. My question is should I mess with it and if so how would I go about it? Just need some suggestions. Thanks. Picture will be posted below.
Old May 30, 2015 | 07:24 PM
Daniel Richards's Avatar
someone replaced the pigtail, these cars only use 1 wire out of the 4-pin connector.
