Looking for EGR connectors
However my harness connector is fine, what I would prefer to do is buy the mating connector separately, which normally is already attached to the EGR valve. I cannot find this mating connector anywhere. Delphi says to go through Mouser, and Mouser says they can't find a mating part number
I don't really want to cut off the EGR connector to wire in the sender but would like some sort of weather proof connection for a tidy install. I guess if push comes to shove I can install a different set of 5-pin mating connectors.
Any ideas? Would any vendors specialize in something like this?
Anyway, Delphi usually has a mating female connector for these sorts of things. If you need one on a pigtail, that will be harder to find.
You may also try posting in the Conversions and Hybrids section of this site. There should be a large number of folks where with experience on these. We also have several sponsors who deal in custom engine/wiring harnesses, etc. and they should be able to set you up with what you need.
