Sideview mirrors motor replacement?
Old Jul 20, 2015 | 05:51 PM
tmdz28's Avatar
Default Sideview mirrors motor replacement?
My car came with the powered side view mirrors and i can only make an up and down adjustments on the driver side and the passenger side is completely dead. since the housing is painted i really do not want to replace the whole thing, just the motor. Is it possible?
Any help is greatly appreciated.
Thanks!
Old Jul 20, 2015 | 06:02 PM
wssix99's Avatar
Save the manuals!
Originally Posted by tmdz28
Is it possible?
Yes. https://ls1tech.com/forums/pontiac-f...ror-glass.html
However; I'd get out an electrical tester and test your switch first. I would expect that having both motors fail on you at the same time would be very uncommon. The switch (or its connector) is a single point of failure here.
Old Jul 22, 2015 | 10:46 AM
tmdz28's Avatar
They are working but very limited of its movement. Now that you mention it, it might be the switch (controller) inside the car that's not working properly. I'll test it out.
Thanks!
