1997 turn signal problems
My problem is the front turns signals. When the car is cool and just started the front turn signals work OK. After it warms up I loose one or both of the front turn signals.
I read about the DRLM being a factory problem and hope that other members can point me in the right direction to fix this.
Thanks,
When things get hot and the signals stop working, do your other lighting functions still work? (DRLs, Parking Lights, etc.)
Problem we found with the Vette is "metal dust" stuck in the oil coating the valve covers. Crap!
Seeing that the owner only experiences the problem while driving and all my test were static, I took it for a test drive. Just as he said the blinker went dead. Finally, after hours of searching I saw the light....or actually the light stopped.
DUH! It is not the module, it is not the full harness, it is not the bulbs or sockets or whatever. IT IS THE HARNESS CONNECTOR on the steering column. 10 minutes of cleaning contacts with scotchbrite and electrical grease and all is well.
Thanks for burning the brain cells but all is fine now.
