Problem with Left Turn Signal/DRL
Thanks in advance.
By the way, My wife jinxed it because she said "why replace that lens when the light is working".
You should have power on the blue wire when the ignition is on, the headlights are off and the parking brake is disengaged. It should change from steady power to flashing power when the ignition is on and that side turn signal is activated.
You should have power on the brown wire when the headlights are on. You may or may not have power there when the parking lights are on - some models continue to use the bright/DRL filament (blue wire) when the parking lights are on without the headlights.
You should have ground on the black wire at all times - the ground is a bolt on the top of the radiator support on each side.
I suspect that if the light doesn't work for either the bright or dim filaments then you have a bad connection on the ground (black) wire. If one works but the other doesn't (i.e. bright works but dim doesn't or vice versa) then it's the power feed for that filament - the socket itself, the connection to the factory harness, or something in the factory wiring.
Ground is good to the body ground at the radiator.
Blue wire is 12V and pulsing when turn signal is on.
Brown wire is 12V when the head lights are on.
If I push the light bulb in really hard, I can get it to light but not flash. I am going to get another socket and try it.
