Factory 02 CD player problems
Old Jan 19, 2016 | 02:13 PM
waltsfastz's Avatar
Default Factory 02 CD player problems
I have 2 of these and they both do the same thing. Put a CD in and it says "err". Is this common? Any fix or are they junk?
Old Jan 20, 2016 | 07:16 AM
WhiteBird00's Avatar
Ungrounded Moderator
Does it give an error number? The list of error codes and some possible fixes is in the Monsoon FAQ sticky.
Are you using commercial CDs or CD-Rs you burned? The player can be very fussy about brand and coatings used in CD-Rs... try using a different brand. Also, burning at 8x-10x rather than maximum speed has been found to help.
Finally, the player will not play MP3 or other compressed formats. The disc must be a standard audio format disc.
Old Jan 21, 2016 | 01:23 PM
waltsfastz's Avatar
No these are regular, off the shelf copyrighted CDs. Ill look at the Monsoon FAQ, Did know about them. THanks
Old Jan 22, 2016 | 05:32 PM
smg267's Avatar
You can pull the top plate off and try cleaning the lens on the cd player. I am having the same problem.
