pillar guages
Old Jun 17, 2004 | 06:12 PM
ss01layinwheel's Avatar
Default pillar guages
I just got my guages for my tripple piller set up. I have an 01 SS. wondering if anyone has any advise on where to run wires through the firewall. any help will be greatly appreciated
Old Jun 17, 2004 | 06:51 PM
ddelallata's Avatar
No problema. under the dashboard on the passenger side. all you have to do is remove the plastic cover that is underneath the glove box. there are two plastic twist off type screws. turn them 90* and then gently pry them off with a flat head screw driver. Once you are down there look up towards the engine bay towards the passenger side wheel well will be a small opening for you to run your wires.
Old Jun 25, 2004 | 12:51 PM
ArcticZ28's Avatar
There's also an opening through the firewall under the dash on the driver's side (which would use less wire to run since it would be closer), but there are a lot of wires usually plugging up that hole. It's all in preference...
