Horn wiring
Old Jun 18, 2016 | 08:52 PM
mngoos's Avatar
Default Horn wiring
OK I am trying to hook my line lock up to my horn button. O am going to use a 5point relay but can't figure out which wire to cut and help or diagrams please thank you
Old Jun 19, 2016 | 08:14 AM
WhiteBird00's Avatar
Ungrounded Moderator
The easiest way would be to use the output from the existing horn relay in Junction box #1 under the hood to power your line lock. The dark green wire at the relay is the 12V output that goes to the horns. Cut that and connect the end from the relay to wherever you need power controlled by the horn switch. You could get fancy by installing a toggle switch there to switch between the horn working normally and using it to control the line lock.
