Radio Bezel Switches
I'd also like an activation switch for giggle gas.
Any chance an aftermarket company has made something plug and play??
If not, is there a writeup on fitting aftermarket switches into the factory location?
Thanks!!
Something else you might find useful... you can buy an electronic control module that will allow you to do a host of configuration things such as make a single pole momentary switch function as a push on-push off switch. That would allow you to use an ASR switch as an on/off toggle for some accessory. You can also do things like one press triggers a device and two presses triggers a different device. The module is the PAC TR-7 available on Amazon for under $20. I always keep one on hand because it is very useful for converting factory switches to other purposes.
I use the stock switches for my line-lock. 2nd switch on the left arms the line-lock and the switch that I have my finger on actives it. you can see the little LED in the vent that shows the line-lock is activated.
