Wiring up Gauges
The gauges a all mechanical apart from 1.
They are autometer LED backlight gauges.
I want the lights to turn on with my parkers.
Do i run a relay in the engine bay fuse box? Ive never done thins kind of wiring before, is the whole fuse box already powered? even the empty relay spots?
If i have to power the relay from the battery what gauge wire and inline fuse do i run?
Do i run a wire from the relay to a distribution block then to the gauges?
Do i wire them in series or parallel?
From where do i get a signal to go from the parkers to the relay?
Do i have to run a second relay which will be switched on with reds to run the electric gauge?
