Alternator noise
Old Sep 5, 2016 | 03:18 PM
David_viny's Avatar
Default Alternator noise
My alternator sounds like a procharger lol. My old one was making this exact same noise, replaced it because of light flickering issues, new one makes same exact sound. I thought it was PS pump but I just replaced that and its not that. Also not water pump, replaced that as well last year... I made a vid of it, if I unplug the exciter wire the sound mostly goes away. It also seems to drag the engine down pretty hard when I plug it in, idk if that's normal... Nothing is on except the engine. I did the sanding of the ground wire locations last year right before alternator, didn't change anything.
Anyone else deal with this?
Old Nov 30, 2017 | 07:54 PM
Luigi66369's Avatar
Did you resolved this problem??
Having the same issue right now on my 2001 camaro. Starting hearing this "whine" and the car died on me while driving about a week later. Had a new alternator and battery installed and still hearing the same whine you show in your video. Whine gets louder as RPMs go up.
Old Nov 30, 2017 | 09:50 PM
HCI2000SS's Avatar
I just had a remanufactured one put in and it now makes that same sound at idle especially. Not sure what to think yet
Old Dec 8, 2017 | 11:36 AM
David_viny's Avatar
Nope, have not tried to fix it yet. It works OK besides the noise so it hasn't been on my need-to-fix list yet. It is very annoying tho because its the loudest part of the car now.
Partially the reason I haven't replaced it yet is because everyone seems to have problems with re-manufactured or "new" alternators for this car and I don't have time to just keep replacing alternators. I may try to rebuild it myself with better quality electronics if possible.
The voltage still dips randomly at idle with nothing but the engine running.
Mine was a "new" one also, made noise since day one.
Old Nov 6, 2020 | 03:26 PM
slowpoke96z28's Avatar
Resolve it? Is it possible the the exciter wire is full fielding the alternator unintentionally?
Old May 12, 2023 | 12:00 PM
GaryDoug's Avatar
I am having the same issue. I replaced the alternator with a new one from Autozone 3 years ago. I noticed it had a high pitch whine but was not too bad. I just installed a new one (AC Delco) after the existing one failed. The noise is much louder now. I also noticed that the volt meter in the cluster shows a higher reading now, just over 14 v, whereas the old one was more like 13v.
Old Jan 7, 2024 | 08:02 PM
draab2006's Avatar
Has anyone ever managed to resolve this? My '00 SS sounds exactly like this, with a brand new alternator (made the noise with the old one, too) and it drives me nuts. I've noticed other F-body's do this too, surely someone out there has figured out a fix!
