amp hookup help needed
Old Nov 12, 2016 | 11:10 AM
zman1969's Avatar
Default amp hookup help needed
Need a little help hooking up a trunk mounted amp- was in another car and moving to another-
it has a PAC line out adapter that was connected to pass rear seat speaker- 4 wires plug green, gray, red, tan wires which of these would I tap into to go back to the amp and stealth sub?
worked great in other car and when removed I didnt take a pic or make a note of how this was done
help?
Old Nov 12, 2016 | 02:36 PM
WhiteBird00's Avatar
Ungrounded Moderator
The wire colors are all listed in the Monsoon FAQ sticky at the top of the section. The right sail panel sub uses four wires because it's dual voice coil but there shouldn't be a grey wire there. One channel is red for positive and tan for negative. The other channel is dark green for positive and light blue with black for negative.
Old Nov 19, 2016 | 11:08 AM
BandDirector Blk98ZM6's Avatar
Yes, read the FAQ's. ALL of the speakers running from the Monsoon amp are crossed over. You'll want to get your signal for your converter directly from the HU.
