How do you mount a gauge in a vent?
**WARNING** I found out the hard way that once you do this, you won't be able to get at the little clips to remove the gauge. So what you might want to do is dremel out that lip on either side, slide the assembly in rotated 90 degrees, then turn it right side up once it's cleared the lip.
