Turn Signal Flasher for Switchbacks
Side Markers (which don't flash): LED
Front DRL/Turn Signals: LED
CHMSL: LED
Tail Parking Lamps: LED
Tail Stop/Turn Lamps: 2 LED, 2 Incandescent
(Gives an almost sequential look to the brake lights although I will eventually swap out the two remaining bulbs to be LED)
It's the official name for the "third brake light".
Thanks
The modification mentioned above (connect the parking light circuit to an ignition switched source and bypass the DRL module) will give you bright white parking lights and DRLs and bright amber turn signals. Whether the turn signals flash amber-off-amber or amber-white-amber depends on the type of switchback bulbs you get.
What you are looking for can't be done without rewiring as described earlier.
The front parking/running lights are the forward facing amber lights which serve as parking lights, turn signals, and daytime running lights. Each of those is a single bulb with two filaments - a dim filament for the parking/running lights and a bright filament for the turn signals and DRLs. On f-bodies, the dim (parking) filament is used only when the headlights are on.
Switchback bulbs are designed to replace the dim filament with white LEDs and the bright filament with amber LEDs. Most people want to use switchbacks to make their DRLs white while retaining amber turn signals but this is not possible without rewiring because the factory configuration has the signals and DRLs sharing the same circuit.
If all you want is to have white parking/running lights but keep the DRLs and turn signals amber then switchback bulbs will do the job. But I'm sure you will be disappointed with the look because the only time they will be white is when you have your headlights on.
The front parking/running lights, after making the wiring changes described, will run the dim filament at all times when the turn signal is not in use. That would be the white LEDs on a switchback bulb. The bright filament will no longer be connected to the factory DRL circuit (the modification substitutes an ignition controlled power source to simulate DRLs on the parking/running light circuit) so only the turn signals will be amber.
My current delima is when I turn my parking lights on the lights come on as white as it should. As soon as I turn the ignition on to activate the DRL function and parking lights off the lights come on as amber as it should. When I lower the parking brake so that the DRL is activated with the lights in the off position the lights are still amber. Now with the ignition on and the parking brake off so that the DRL is activated and I turn on the parking lights the lights remain amber. Anybody know why this is happening? Any help would be appreciated, thank you!
On my 76 Trans Am I got lucky with the flasher and just purchased a new flasher and it ended up working with those switchback LEDs. I hope I can do the same with the 01 and just purchase a new flasher at my local auto parts store and have it work.
Thank you again.
