in car wiring help needed, lt work for ls?
Thanks
Generally, the connectors that plug into devices (BCM, switches, relays, etc.) will be the same but the wiring will be different and sometimes the connectors between harnesses (e.g. at the firewall) can be different as well.
Would this harness work? Or be close enough...
Best guess... there is no way that harness will simply plug in. It's probably something that can be modified to work but the amount of modification will likely be quite extensive. It would be better to start with a 98 Firebird harness to minimize your cutting and splicing.
