2012 Ford Fusion AC issue
Old Apr 8, 2017 | 02:36 AM
yeleka's Avatar
Default 2012 Ford Fusion AC issue
Car blows hot air. Changed the Acculator (Hot cold) under dash and no change. Unplugged hot and blows cold. Mechanic says BCM needs replacing . Dealorship issue. Will a preprogrammed used BCM work without dealer programming
Old Apr 8, 2017 | 07:10 AM
WhiteBird00's Avatar
Ungrounded Moderator
Perhaps you might have better luck asking on a Ford forum such as www.fordfusionforum.com or www.fordfusion.org. This is a General Motors forum so any discussions about BCMs here are not related to your vehicle.
Old Apr 9, 2017 | 08:30 AM
G8One2's Avatar
If you replaced the blend door actuator, there is a learn procedure involved for that. The BCM should not need replaced. The dealer is just trying to get you to buy one. I dont remember what the procedure is, but i know there is one. I believe you have to remove a fuse, key on, key off type of thing. It has to learn its position.
