Installing multiple electronics - Run power through firewall or use accessory wires?
I have the following devices:
Gauge cluster LED (custom, not using stock cluster, a separate wire has to be run for illumination)
Dash Computer
OLED Computer
Viper Alarm
GPS / GSM Fuel pump shut down
2 USB Hubs
The Viper Alarm and GPS need CONSTANT power
ALL of the above devices need IGNITION power as well (meaning the Viper Alarm and GPS/GSM Device needs BOTH sources)
If I ran a wire from the Fuse Panel ignition accessory wire and divided it between all of these devices, would it likely overload the circuit? Should I run external power through the firewall and RELAY it to that ignition source wire?
