Keyless entry/BCM
Old Apr 30, 2017 | 12:44 PM
Guillaume Malaquin's Avatar
Default Keyless entry/BCM
Hi from France.
I have a Camaro V6 2000 3.8 since last year without keyless entry, and it's annoying ahah.
​​​I have a ----681 BCM without alarm and Keyless entry. But I have power lock doors and, I just installed the rear hatch actuator and switch 'cause I was pre-wired. So I would buy an used BCM ----691 BCM with my VATS code. But the guy says to me it may be not working with the just the BCM, because I not may be pre-wired for send the information to the actuator door lock??
How check if I have everything but the right BCM? Because a BCM is costly to import, and we don't have Camaro in jackyard here do take the parts.. So I won't buy one for not working, it's seem normal.
Thanks, for the informations!
A bientôt !
Guillaume
Old Apr 30, 2017 | 03:39 PM
JOHNNY59's Avatar
Originally Posted by Guillaume Malaquin
Hi from France.
A bientôt !
Guillaume
I have done this swap (681 to 691 BCM) a couple of times without a problem. 98-02 f-bodies (don't know about other years) are pre-wired and are good to go. If you need further help or a bcm PM me.
Old May 1, 2017 | 01:49 PM
Ok thanks JOHNNY59, I bought one 691 UPL, coded for my VATS. I will see when it come from Florida to France (~8-13th May). I'll keep you tuned, thanks you !
A bientôt !
Guillaume
Old May 11, 2017 | 08:28 AM
BigFellor's Avatar
Not intending to hijack the thread but how do you tell which BCM you have?
Just bought a 99 Firebird as a project / toy and it has power locks and such but no key fob. Would like to get one and get it all back to working as it should.
Edit: Found the answer here
https://ls1tech.com/forums/stereo-el...ess-entry.html
Old May 11, 2017 | 11:05 AM
Hi everyone !
I just received mine BCM today, installed in 20 minutes and it's work great ! The actuators move and the rear hatch pop up in the programming mode
Thanks !
