Replacement harness clips
Old May 9, 2017 | 10:31 PM
HappySalesman's Avatar
Default Replacement harness clips
Anyone know where/if its possible to get replacement harness clips? Half of mine are broken and I want to replace them. Certain ones I know are universal/can be replaced with aftermarket parts, but others not so much. Specifically I need the clips that hold the speed sensor harness onto the lower a-arms.
Old May 10, 2017 | 07:36 AM
WhiteBird00's Avatar
Ungrounded Moderator
The parts manual lists a "bracket, wheel speed sensor wire" for 93-96 as part number 18018555 but for 97-02 it's listed as N.S. (not serviceable). It would not be unusual for it to actually be the same part but there's no way to know without looking at an earlier model and comparing. Besides, the bracket is shown as bolting to the back of the spindle so it may not be the one you want.
Other than that, there is a sub-harness for the wheel speed sensor that may have the clip included (hard to tell by the drawing). For 00-02 it's part number 12177650 specified as 700mm (about 27.5") long.
Old May 10, 2017 | 09:02 AM
brutalis's Avatar
A cheap option would also be to buy "push-mount cable ties", which are just zip ties with a stud/clip on the end to mount through holes in sheet metal/plastic/etc. I used a lot of them for my rewire project.
Old May 13, 2017 | 10:54 PM
wssix99's Avatar
Save the manuals!
They should be Delphi parts and have GM-formatted parts numbers. The hardest part is looking up the numbers. Often times, Delphi will change the part, substitute the number, and then the change won't carry all the way through the GM parts catalogs.
Sometimes, if you have the original GM part number, you can figure things out by searching the online Delphi catalog with it.
