Car Lights
The bulbs are dual filament so the fact that the running lights work does not mean that the brake light filament in the bulb isn't burned out. You can test for power and ground at the bulb sockets using a test light or multimeter. If you have both then either the bulb or socket corrosion is the problem. If you don't then you need to trace the wiring to find out why.
