Replacing terminated leads
Anyway, I've been having issues with losing ABS when hot and most of the female terminals look to be in very bad shape. Is there a good source for terminated leads to replace these, or should I just find a junkyard connector and hope for the best?
GM gives dealers terminal repair kits to change these pieces out. Here is a current manual: http://www.weber.edu/wsuimages/autom...ir Booklet.pdf
It's pretty easy to change the terminals out and all the parts can be had from places like Mouser for very little expense. (I've rebuilt a number of my car's harnesses and they are as good as new.) The hard part (sometimes) is identifying the terminal/connector type so the proper part number can be looked up. I have other references for that if you ever have the need.
The other key piece is that the proper ratcheting crimpers are absolutely required. The part numbers are given in the Terminal Repair Manual ^ and these pieces are the most expensive part of the whole deal. (But, you only have to buy them once.) I was able to get most of mine off of eBay when all the GM dealers were closing several years back. Sometimes they do pop up for good prices there.
From there, I've found that this catalog is the next most helpful: ttps://www.powerandsignal.com/docs/DCS Global Catalog.pdf
^ These take care of 90% of the situations.
If it's not in the catalog, I can help you track it down. There are other resources. Are these connectors that go directly in to ABS sensors?
