Need with a switch for fans
Old Jul 24, 2017 | 02:10 PM
biketopia's Avatar
Default Need with a switch for fans
Ok so I'm doing a SBC swap from the LT1 that was in my car and going through the motions of getting wiring knocked out. I'm putting a SPDT switch in to manually control the ground for the fan relays via the factory wiring at the connector on the shock tower on the passenger side. Now my question, I want to wire up two LED's to operate in conjunction with the switch. I'd like for 1 to be on in low and both to be on in high. I've drawn the diagram out on paper and I think it might maybe work, then I look again and second guess myself and think that the LED circuit will provide a path to ground for the other circuit while the other is in position. Can someone help me out, or tell me I'm over thinking it on a Monday and just go for it.
Old Jul 24, 2017 | 08:01 PM
biketopia's Avatar
Ok after more looking and working with the diagram I realized where I went wrong with my SPDT switch, need a DPDT switch, and found exactly the info I needed from some searching on shoebox's site. That place has been invaluable for this endeavor!! If some one stumbles on this here is the link to the diagram. http://shbox.com/1/fan_sw_diagram1.jpg
