Installing indash stereo 99 camaro
Old Aug 22, 2017 | 06:16 PM
Maguilacutty's Avatar
Default Installing indash stereo 99 camaro
So I just hooked up a jvc indash and am trying to get my speed to sync with the unit. The indash has a wire that you can hook up to get the speed but I'm not sure where I need to run this wire in the car.
Old Aug 23, 2017 | 07:07 AM
WhiteBird00's Avatar
Ungrounded Moderator
The Camaro already had that signal in the factory harness because it had speed sensitive volume in the head unit (Firebirds do not have that wire). You want to connect to the dark green with white wire in the white connector on the factory side of the stereo harness. There may or may not be a corresponding wire in the adapter harness so you may have to connect directly to the factory side wire.
