Does any make a sub box for Driver side that actually Fits?
Old Jan 20, 2018 | 09:40 AM
BandDirector Blk98ZM6's Avatar
Originally Posted by michaelhawk
The CD Changer has to be, and is, removed.
The bracket that holds the changer is also removed too? The boxes are designed to fit in the cubby hole that never had a changer mounted AND the black plastic grill that's at the back of the cubby on the bottom has to also come out. I moved my changer to the passenger side and the bracket that holds the stock changer in place has to also be removed, or the box has to be modified to fit around it. I actually notched my JL box to fit around it and then re-sealed it from the inside of the box.
Old Jan 20, 2018 | 12:00 PM
michaelhawk's Avatar
Thank you but I've explained in detail why each doesnt fit, it has nothing to do with the cd changer and its bracket. One is too high on the end as pictured. the other is too deep for the firebird as described.
Old Jan 22, 2018 | 06:00 AM
biketopia's Avatar
Thanks for the link.
