Front/Rear Cameras
I have a double-din radio and a rear camera.
This is honlestly something I thought of as well. My driveway is pretty long and I tend to make a semi circle and back in at a n angle to make pulling out easier. Trouble is there is a retianing wall that I nose up too pulling in. When I bought my head unit it came with a back up camera which is a bit too chunky to be mounted on the GTO but would fit the front behind the lower grill just fine I think so I had considered playing around with it.
lighted pushbutton switch that has NO and NC contacts,a relay I run the video inputs thru.
Ive got both mine in the rear(one off center to take care of the blind spot) only aftermarket parts I used are the cameras(gms suck)and switch. I added a mirror from later model GM that has the onstar and video display which is the ****. you can pick up a mirror for about $60 on fleabay.I have one powered off the reverse light and the other thru the switch so I can turn it on while driving.I also replaced the backup lamps with some killer LEDs so its like daylight when in reverse and the camera loves it.
