Tweeter placement question and build log
I'm going to add some pics of what I've done so far in following posts in case it helps someone.
Deck: Pioneer DEH8700
DSP: Audison BitOne
Amp: Alpine PDF v9 5 channel
Subs: Two older 10s in separate 0.70 ft3 boxes
Mids: Steven's Audio MB6-4
Tweeters: still deciding
Midbass was something I was always lacking in my previous car stereo upgrades so I really wanted to improve on this as best I could. After a lot of research online I started the process by stripping down the door and adding a layer of Hushmat/Dynamat damping to the outer and inner door skins to help with vibrations. I went single layer and used about 8 sqft per door. I filled up the larger opening towards the rear of the door with some dampened sheet metal. and filled as many smaller holes as I could with the Hushmat. After that I trimmed a piece of 1/8" mass loaded vinyl and backed it with some 1/8" closed cell foam. I used Velcro tape to hold the sheet of MLV/CCF on the door as detailed on SoundDeadeningShowdown website. The weight of the MLV was stretching the adhesive over time and causing it to slide off so I added some staples to prevent the shearing.
I had some 1/4" plywood kicking around so I figured I would use that to make the mount plate. I traced the plastic mounts onto the plywood and added material where there was room to add it. You will need the extra thickness if you want to attach mdf speaker rings like I was planning to. If I was going to do this again, I would not use 1/4" plywood. The inner layers of plywood separated a bit when using the scroll saw and then fell off along the outer edges. Luckily I had some liquid shim material I was able to use to fill in the gaps.
After cutting out the plate I glued and screwed 5/8" thick mdf rings I had purchased online to fit the midbass I had. I then hit them with some bedliner spray paint to try and give them some water resistance. One thing I noticed about our doors was there seems to be a lot of water ingress from the elements. I wanted to maintain the rain shield feature of the factory mounts so I used some 0.020" aluminum sheet to recreate some rain guards, I think they will do the job.
The diameters of my new speakers with the mdf mount were about .75" larger than my old setup. In order to get the door panel to fit I had to trim as much plastic/cardboard/insulation as I could from the rear side of my door panels. The area that I trimmed was around the recess that goes around the speaker. Getting the door panels back on with the larger speaker and layer of MLV/CCF was NOT easy but eventually I got them on.
My impressions so far driving just the midbass from my amp at 100watts each is really good. Definitely getting a much better bass response in the 80-500 range than I was before. I'm getting a little vibrating from the door panel towards the rear of the door. I may pop off the panel and add some more damper there but I'm debating if it's worth the struggle to get the doors back on lol. All in all, I think it was worth the effort to go damper, ccf, and mlv. Next up is deciding on a tweeter and figuring out where to mount it.
