Auto meter shift light
Old Feb 13, 2018 | 04:34 AM
Chased's Avatar
Default Auto meter shift light
https://www.autometer.com/2-1-16-dig-pro-shift-1-stage-phantom.html
anyony running this one? Install pictures? Anything? I did a search and came up with nothing
Old Feb 22, 2018 | 01:47 PM
FCar2000TA's Avatar
Veteran: Air Force
I have one. I got it with their 2 pod a-pillar addon. It was pretty easy to install. You just supply power, and tap into the TAC wire at the ECU.
I mounted two fuse blocks and a grounding block on the plastic cover under the steering wheel, and used that to wire BAT and ACC power for the AFR guage and the tac/shiftlight.
BAT power and tac signal wires were routed through the firewall grommet behind the ECU.
ACC power came from an open spot on the factory fuse block.
I might have a pic of it all installed. I will look.
Old Feb 22, 2018 | 01:58 PM
FCar2000TA's Avatar
Veteran: Air Force
Old Feb 22, 2018 | 02:02 PM
FCar2000TA's Avatar
Veteran: Air Force
I got a can of spray paint from a shop that could use the door code to get the color. Then I used high tinsel strength glue to mount the gauge pod to the a-pillar. Turned out pretty good for something I have never done before.
