VATS Question...
Old Feb 18, 2018 | 07:15 AM
HorsePower Junkie's Avatar
Default VATS Question...
Will the starter crank at all, even a little bit, If VATS has an issue?? (on a 2001 Z28)
Old Feb 19, 2018 | 08:57 AM
WhiteBird00's Avatar
Ungrounded Moderator
No. The BCM does not supply ground to the starter relay coil unless it sees the correct resistance value in the key pellet so the starter won't even start to turn over if it doesn't. Besides, if you have a VATS problem, the SECURITY light in the instrument cluster will be on or flashing (on if it sees a pellet that's the wrong resistance, flashing if it can't see a pellet at all).
Old Feb 19, 2018 | 09:27 AM
Thank you for answering WhiteBird00, and thank you for your PMs!
You are sincerely appreciated!
