Charging system
Old Apr 22, 2018 | 09:45 AM
sandman54's Avatar
Default Charging system
I have a question my 01 ss charges slightly higher than other vehicles I’ve owned... according to the gauge it look to be charging at 14-15.5 amps.. should I worry about this? I used to vehicles charging around 12.5-14 amps
Old Apr 22, 2018 | 10:21 AM
LLLosingit's Avatar
That would be volts not amps and it's not a problem, The gauges are not always that accurate anyway. If you see over 17-18 volts then you should check it with a hand held voltage tester.
Old Apr 22, 2018 | 11:52 AM
sandman54's Avatar
Thanks
