How are the sail panel subwoofers controlled?
If you are retaining the Monsoon amp then no crossovers are necessary. If you are replacing the Monsoon amp with an aftermarket one then you should rewire the subs to use the sub (low pass filtered) output of your aftermarket amp. If you're trying to bypass the Monsoon amp to run just off the head unit... why would you do that?
