99 trans am dash lights
Old Nov 3, 2018 | 01:13 AM
odriftwood's Avatar
Default 99 trans am dash lights
my dash lights flicker each bulb will independently flicker randomly,any help would be very cool.
Old Nov 11, 2018 | 07:29 PM
dreww's Avatar
Dash lights get power via dimmer switch next to headlight switch. Probably a dimmer switch issue
Old Nov 12, 2018 | 07:27 AM
WhiteBird00's Avatar
Ungrounded Moderator
While that is possible, all dash lights run off a single wire from the dimmer switch so it would be expected that all would flicker at the same time if there was a problem with the switch. It is quite likely that there is a problem with the printed circuit board on the back of the instrument cluster with cracked traces and/or loose connections.
