Taillights not working properly
How long have you had this problem?
Do you have any LED lights installed? If so, have you tried putting conventional bulbs back in?
Assuming Camaro (from your avatar), there is no white wire in the factory tail light harness. First thing I would do is disconnect that white wire. Then I would check the tail light grounds - your symptoms sound exactly like what happens to lights that don't have a good ground... the current back feeds through the other filament in the bulbs and ends up feeding other circuits. That's the only way the third brake light would be affected by turn signals since the two circuits aren't normally connected to each other (other than the tail light bulbs sharing a common ground).
