Trying to keep vats
Old Oct 23, 2019 | 10:34 PM
William Gilligan's Avatar
Default Trying to keep vats
I swapped a 2001 6.0l lq4 and pcm oug of a truck into my 2000 camaro v6. About ready to start up but want to to keep stlck functions of key. Do I have to remove vats or are there any wires I need to run to the pcm. Please any help is appreciated first ls swap and I'm new to the site so if this has been answered before I'm sorry.
Old Oct 24, 2019 | 06:55 AM
WhiteBird00's Avatar
Ungrounded Moderator
The only part of VATS that involves the PCM is the fuel enable signal. The BCM disables the car when it doesn't see the correct key by blocking the starter relay ground (to prevent cranking) and disabling the fuel enable signal to the PCM (to prevent the car from running). The fuel enable signal is on the dark blue wire in position D8 of the blue BCM connector. The PCM can be programmed to ignore the lack of a fuel enable signal or the truck PCM may not even expect one so you could retain the starter inhibit part of VATS without being concerned about the PCM.
