Kicker door speakers...
What I did is a bit different and many would consider what did the wrong way to do it. I ended up using Kicker CS coaxials for the doors. Some will say that is too much tweeter. Well, the stock tweeters are powered by the head unit and are pretty weak sounding. Having some extra tweeter doesn't seem to be overpowering. With the TA, I have the equalizer to pull down the high end if needed. Also, in comparing the Kickers to the mid range components I was looking at, the Kickers seem to have a lower bass range. To me it seems to have a pretty full sound. I don't need a huge sub to shake every bolt loose on the car.
