1994 possible wiring issue
Old Oct 12, 2020 | 02:59 PM
Wildcat58's Avatar
Default 1994 possible wiring issue
Have a 1994 firebird, just replaced the entire interior including dash and steering column from a donor car, before the swap I didn’t have a key but the car would at least crank with a screw driver, now I have a key with the new column but the car will no longer crank, all of the lights work and radio, but the car will no turn over, I tried to put the old column back in just to see it it would crank again but it no longer will. There was a security light on with the old column because of the vats im assuming but now that light is no longer there with either column. Tried to see if maybe I missed something that was not plugged in but no luck, any ideas?
Old Oct 13, 2020 | 07:15 AM
wssix99's Avatar
Save the manuals!
Moving to Stereo & Electronics.
If your old car turned with a screwdriver and had VATS, it must have had a resistor spliced in to bypass the VATS.
On your new setup, your BCM (wherever it came from) will need to see a roper VATS resistance before starting.
Old Nov 24, 2020 | 01:38 PM
QuandAns42's Avatar
Are you sure the donor dash was compatible? If it wasn't you may have some fried wiring. Check the instrument cluster store online if you end up needing a new cluster.
Last edited by WhiteBird00; Nov 25, 2020 at 07:34 AM. Reason: Removed non-sponsor link
