Led dash light conversion
Old Oct 19, 2020 | 04:23 PM
LS264elcamino's Avatar
Default Led dash light conversion
I purchased 194 replacement led bulbs. I tested each bulb before installing them and all worked. After putting the dash cluster back in none of the led bulbs worked. Knowing led bulbs are polarized I removed them and turned them 180 degrees. I put the dash back on and again none of them worked
I am looking for suggestions on this problem.
Old Oct 19, 2020 | 06:34 PM
VIP1's Avatar
Copy & Paste Moderator
Make sure you didn't accidentally turn the dimmer all the way down. Also, drop-in LEDs typically have a narrow dimming range so turning up the dimmer may be all that you need.
Old Nov 16, 2020 | 07:20 PM
wannafbody's Avatar
I had a similar issue and had to tweak the metal connectors to make a better connection with cluster.
