Issues with headlight harness 02 Trans Am
Some other higher end brands to try are Diode Dynamics and VLEDs. I don't have any personal experience with them but they get good reviews.
Also make sure whichever ones you get have a good heatsink on them and possibly a fan. The high beam ones I bought don't have a fan, but I don't use the high beam much and the back of the bulb is fully exposed to the air and not covered inside a housing.
BTW - I was in the hardware store today and saw "Needle File Sets". These would be perfect for filing the corrosion off the terminals in the motor connector. I wish I had thought of this before. It would have made faster/easier work out of it.
Some other higher end brands to try are Diode Dynamics and VLEDs. I don't have any personally experience with them but they get good reviews.
Thanks for the info
I just need to get my light working right, for now, so hopefully these will work, then I'll piece together the LED kit yet.
Could this be an expanded issue, from when you said that the wires in the motor was bad and possibly causing my light issue?
Which HL motor is considered the "primary" motor, for the issues I'm having, with the lights, or can both be equally at fault? I'm wondering if I should just say screw it and replace both motors, instead of just replacing the connectors, to try am eliminate my headlight issues.
I hope I explained this clear enough, I'm on my pain meds so...
On the headlight going down, this could be a stripped headlight motor gear or a solder joint crack problem in the headlight control module. (If you aren't hearing grinding and it's getting more frequent over time, I'd guess the latter. There is some recent discussion in the Firebird section under the headlight sticky on this problem.)
For the problem you are having with the shorts, it can be either side. They are connected together. If you disconnect each side one-by-one, the bad one will be the disconnected side when the connected side works properly. Either way, if you are going to the trouble of disconnecting the connectors, you should be able to clean them up with some needle files and be good for years until the problem comes back.
