Alternator Amps for Stereo
Old Mar 7, 2021 | 07:21 PM
350 groundpounder's Avatar
Default Alternator Amps for Stereo
Curious of allternator options for my 96 z28. I have two amps with about 1300 RMS total going to the speakers. Should I move up from stock to prevent amp clipping?
Old Mar 8, 2021 | 05:17 PM
JonAdkins's Avatar
Large case truck alternators fit, I would look into a Mechman 240 amp. That'll laugh at that system. I have a Orion 500.4 and a 650.1 so about 1150w RMS and I run a Tuff Stuff 175 amp and it holds mine at 14.2 and over 13.5 with heat and head lights on in drive, idling.
Old Mar 9, 2021 | 08:25 AM
Thanks Jon. I will look into the tuff stuff 175. The Mechman 240 alt says its not recommended for rpms over 5500 rpm? I regularly hit 6200 rpm.
Old Mar 10, 2021 | 05:18 AM
JonAdkins's Avatar
I need to pay attention more, you said 96 and I was thinking LS1 like my car. I would go to Singer Alternators and get a quote from Mike. Tell him what amps and accessories you're running or plan on running and he should get back to you fairly quickly. Mechman does however make a 250 amp for LT1s for $500 and a 370 amp for $600. Both would be pretty overkill.
Old Mar 10, 2021 | 04:53 PM
Thanks, i will check out Singer.
