99+ M6 Harness into 98 Auto
Like the tittle says I am in the process of swapping in an M6 99+ harness into 98 A4 T/A.
I figured 95% of it out and re-pined the C- connectors to make it all work, but I had some questions.
How would I go about wiring the reverse lights? since I have the T56 harness the reverse light switch on the trans can just plug in to the harness, but the lights would still not work as they are ran through the neutral switch on the Auto, how would i go about wiring this up?
Thank in advance.
To swap from automatic to manual (or vice versa), all that's necessary is to route the brown wire and the light green wire to the correct switch and connect them to to the switch terminals. There are no other sensors or devices involved - just power to the switch and output to the lamps.
