2001 Camaro Tachometer
Old Apr 19, 2021 | 10:49 PM
Juan72's Avatar
Default 2001 Camaro Tachometer
Hey! New to this forum,
Just changed out my 01 Camaro bulbs to LED bulbs in my instrument cluster after putting it back in the tachometer begins at 2000RPM instead of starting at the usual 800 -1000RPM range any Idea on how to fix this?
Old Apr 21, 2021 | 03:36 PM
VIP1's Avatar
Copy & Paste Moderator
Did you remove the needles? If so, then you put them back in a different position which now means they read wrong.
Old Apr 21, 2021 | 03:51 PM
01CamaroSSTx's Avatar
Was it at zero before you connected back up?
Old May 31, 2021 | 04:11 PM
Juan72's Avatar
I did remove the needles because one of them ended up breaking as I was trying to put in an overlay so I had to buy a new needle, anyway of recalibrating it? I'm assuming I would have to use a scanner when the vehicle is on and put it right back in a matching spot
